Hi all
I have a simple sample bellow and would like to bend A and B in one Direction, lets say upwards and C the opposite direction.
This is just one experiment, please don't mind sketch not fully constrained and a bit sloppy. and the gap in between A, B and C can be removed, was just me trying to work it out.
Solved by laughingcreek. Go to Solution.
having the bend line for both the down bend and the up bend seems to be tripping fusion up. moving the bend line for the up directing ever so slightly forward might be a viable workaround for you-
