Fusion - Reference orientation for mesh generation
felix.wienker
felix.wienker
For some bodies, the orientation of the sketch seems to impact the mesh quality:
A) Sketch created in YZ plane and revolved around Y axis:
  • When exporting the body as mesh, this results in a very non-uniform mesh.
  • Mesh hotspots with high density are very visible in 3D print.
  • Very high triangle count in mesh export needed for good results.
B) Same sketch created in XZ plane and revolved around Z:
  • Mesh export leads to a uniform mesh, even with lower triangle count.
Is it possible to define a reference orientation for mesh generation or "save as mesh" to optimize the mesh alignment?
This post has been edited due to: @lauri_barnhart added the product to the title to help more community members find this topic.
heather_tracy
Hi @felix.wienker,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Heather | Community Manager
