Fusion Non-linear Analysis Bisection Error
I ran a non-linear analysis for a on a rubber part which is in the middle of 2 iron plates. There is pressure acting on the top part of the iron plate. the structure is surrounded by an iron tube. I have attached the picture of the simulation and structure that i wished to do. The simulation could not be solved and it show the message below :
*Error: MAXIMUM NUMBER OF BISECTIONS PERMITTED REACHED
 Cause  : The bisection limit specified on the NLPARM (static solutions) or a TSTEPNL (transient
              solutions) Bulk Data entry for the current load increment has been reached (default
              5).
 Action : Increase the bisection limit and/or investigate the reason for the load bisection.See
              message E5075 above.
henderh
Hi @Anonymous
Could you attach the setup here so we can take a closer look? File -> Export...
Thank  you,
Hugh Henderson
QA Engineer (Fusion Simulation)
