Looking for the bet approach to import a path with locations from another cad program. Then place/align Fusion configured parts on each location.
Image A is the path and marked locations being imported. the locations could be 2d, 3d or a centerline depending on what makes the most sense for fusion. I did import this into a sketch, but it seemed like a lot of work to constrain all the objects.
Image B is rough approximation of the fusion parts to place along the path. each being a configuration of a different height. I think I can do this part OK, Just trying to figure out the path of least resistance to get the path and placement locations and angles into fusion.
Redrawing in Fusion isn't a good option as it needs to be precise and there are spiral curves I do not want to try to replicate.
TIA
Dave
This post has been edited due to: @lauri_barnhart added the product to the title to help more users find this topic via external search.
