Fusion - Need help learning efficient workflow for importing path and placement drawing from another CAD
djtowle
djtowle
Looking for the bet approach to import a path with locations from another cad program. Then place/align Fusion configured parts on each location.
Image A is the path and marked locations being imported.  the locations could be 2d, 3d or a centerline depending on what makes the most sense for fusion.  I did import this into a sketch, but it seemed like a lot of work to constrain all the objects.
Image B is rough approximation of the fusion parts to place along the path.  each being a configuration of a different height.  I think I can do this part OK, Just trying to figure out the path of least resistance to get the path and placement locations and angles into fusion.
Redrawing in Fusion isn't a good option as it needs to be precise and there are spiral curves I do not want to try to replicate.
TIA
Dave
This post has been edited due to: @lauri_barnhart added the product to the title to help more users find this topic via external search. 
SaeedHamza
This is technically possible in Fusion, but not really as a clean native workflow. Importing the path is one thing, but automatically placing and aligning configured parts at each imported location is the hard part, especially with spirals or 3D curves.
For a few parts, manual setup might be fine. For anything serious or repeatable, I’d use the API.
Saeed Hamza
lauri_barnhart
Hello, @djtowle,
Did the information provided by @SaeedHamza help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
Let us know how we did on Trustpilot.
