Fusion is not exporting DWG, PDF, IGES, or anything
I don´t know what's happening, Fusion won't export my design. All PDF and DWG files are 0KB.
I would share my design, but...
kris_berg
Hi @Anonymous,
I am sorry you are having this problem.  Can you try saving the .pdf or .dwg to a directory in C: that has no special characters?  By special characters I mean, create a directory using only using only characters A-Z, a-z and 0-9?  The file name you create should also have those limitations.  Using any combination of characters should work, but I want to try to diagnose why you are seeing this.
If this does not work can you share your drawing with me?  To share a drawing, right click on the drawing in the data panel and select "Share Public Link", then send the link to kris.berg@autodesk.com.  Be sure to allow the drawing to be downloaded.
Thank you,
Kris Berg
Senior Software Architect - Autodesk
Thanks for the reply! But I found the problem: My disk was full.
