Fusion Drawing input fields lose focus when moving mouse outside the properties panel
officeZJ276
officeZJ276
I’m experiencing a very frustrating UI issue in the Drawing workspace in Fusion.
When editing drawing annotations/dimensions, Fusion opens the small properties/editing panel on the right side where values, text, font settings, etc. can be changed.
The issue is:
  1. I click into one of the input fields.
  2. The text cursor/caret appears and I can type normally.
  3. As soon as I move the mouse cursor even one pixel
    outside of the panel,
    without clicking anywhere, the text cursor disappears and the input field loses focus.
  4. I then have to click into the field again before I can continue typing.
    (view in My Videos)
This makes editing dimensions and annotations unnecessarily frustrating, especially because normal mouse movement while typing is enough to interrupt the input.
Expected behavior
Once an input field has been clicked and is active, it should remain active until I:
  • click somewhere else,
  • press Enter/Tab/Escape,
  • or otherwise deliberately leave the field.
Simply moving the mouse outside of the panel should not remove keyboard focus, like in any other Fusion Workspace.
Also, does anyone else have the same problem, that everytime I open a new drawing, my NVIDIA driver boots and freezes a couple of seconds while booting?
Only happens in the Drawing Workspace, but not in the Desgin Workspace.
Is anyone else experiencing this?
Is this intended behavior, a known issue, or a bug?
I can also provide a short screen recording demonstrating it if helpful.
liang_chen
Thanks for sharing the feedback. It has been tracked as an improvement and sent to dev team for planning. The internal ID is FUS-269997.
Fred Chen
SQA Engineer
Quality Assurance Team
