fusion doing funny stuff
daniel_lyall
Mentor Mentor
daniel_lyall
I have a strange problem in the model attached if I change a user parameter that is a height change it cuts the model in half in the width you can see it in the screen cast as well.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
catot
It changes the profile used for the cutting operation. Looking at Sketch8, the height is 50mm (but not dimensioned, the lines are fixed), and at Sketch 2 you still have a 50mm line to the right, but the actual height is 60mm, so it's no longer a closed profile, and then it gets deselected for the cut-operation.
I would advise you to avoid using the Fix-constraint. Also, try to fully-constrain all the Sketches with Dimensions, then it all will behave more predictably during dimensional changes.
daniel_lyall
@catot thanks for that I removed all constraints dimensioned it and put constraints back where they were needed, there were some other problems removing the constraints showed it.
so thanks it's all working now if I just did but joints or mortise and tenon joints it would of been easier.
I hate doing no nail or screw furniture designs
Daniel Lyall
The Big Boss
Mach3 User
