Fusion Does Not Start
Fusion 360 installed and ran the first time.  Now it won't start,  does not appear on the Start menu, when trying to reinstall it says"You have the latest version of AutodESK fUSION 360.  wOULD YOU LIKE TO START THE APPLICATION?"  i CLICK yES.
The system cannot find the file specified.
innovatenate
Autodesk Support
Autodesk Support
It sounds like an issue with the start up icon.
Could you try browsing to and launching the below executables?
%localappdata%\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe
or
%localappdata%\Autodesk\webdeploy\production\fd49077b95f59b260407eb4bc8813cbec36364b9\Fusion360.exe
You may consider creating a new shortcut icon on your desktop and removing the old one.
Please let me know if you have any difficulties locating the files.
Nathan Chandler
Principal Specialist
No match below
innovatenate
Autodesk Support
Autodesk Support
Did the other directory work?
Below is a screenshot of my directory. You'll note that there are multiple folders in the production directory.
It may help to sort by date created or date modified and then search for the Fusion360.exe.
If this doesn't work, it may be easier to perform clean uninstall (see below link) and the re-install fresh.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
I hope this suggestion helps. Please let us know either way!
Thanks!
Nathan Chandler
nks solved the problem
