Fusion crashes when using move tool in edit sketch
Hello,  I keep having crashes when trying to move a spline tool sketch.  Fusion continues to lock up and crash.  It does it on multiple machines.  Any ideas?Fusion 360 crash.png
jeff_strater
that is likely not a crash at all.  Just from the subset of what I can see in the image, this is a VERY complex sketch for Fusion to handle.  Lots of splines and each spline has lots of fit points.  Most likely, if you let this go, the operation would succeed, it will just take a long time.  Fusion is not intended to be used to edit complex sketches, and will not perform well with that kind of data.
If you can separate out your design into multiple sketches and simplify the splines here (you can probably get by with many fewer fit points), you will be much happier.
Jeff Strater
Engineering Director
