I debugged this and I see what the problem is. You must have edited one or more of the materials you are using in your document using the Material Manager, in the Document Materials area. You then have some components suppressed/hidden. The combination of a modified document material and suppressed/hidden components is causing the crash. I can reproduce this from scratch. I cannot think of a way to edit your study to get around the issue, unfortunately unsuppressing/showing all components won't avoid it. We will look into getting a fix out for this as soon as possible.
Create a new study (don't clone the bad one) of the same type, then Copy/Paste your loads and constraints from the old to the new study. If you have changed other settings (mesh settings, etc.) you will need to change these manually. In Manage Materials you need to copy the base materials you want to your favorites library and edit them there. Then you can choose the favorites library in Material Manager and assign the materials to your parts. Do not edit the 'Document Materials'. This should get you back up and running while we work on a fix.
Sorry for the inconvenience.
Rob McMillan
Software Architect, Fusion Simulation
Rob McMillan
