Fusion craches
Fusion craches
Fusion craches
When updating an assembly change in another assembly FUSION craches.
innovatenate
Autodesk Support
Autodesk Support
Can you Export from the A360 dashboard of the design (please export an Archive *.F3Z file)?
Next, can you create a public link of this F3Z file and share it with me Nathan.Chandler@autodesk.com?
This file will help me to better understand the root cause of the error.
One suggestion may be to re-open the updated assembly and perform a Compute All from the Modify drop down menu. If there are any errors or warnings in the timeline, resolve them and then save a new version. Last, re-open this design and attempt to update again.
Hope this helps! Let me know if you have any questions.
Nathan Chandler
Principal Specialist
Hi there,
I tried has you said the compute all command, but when I update it it still crashes.
Thanks for you help, for know there are 2 colleagues of yours from support working on it (bankim.charegaonkar@autodesk.com ; matt.pooley@autodesk.com ), I dont think its necessary to involve a third person on this, but if you want to give an different insight you can contact then.
Best Regards,
Miguel Pereira
innovatenate
Autodesk Support
Autodesk Support
Thanks for the update! You are in capable hands with Bankim or Matt.
Cheers,
Nathan Chandler
