Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fusion 360 will not launch
3 REPLIES 3
llee
923 Views, 3 Replies
The error dialog box is titled "NLauncherConfigurer.exe" The message: "The program can't start because acge222.dll is missing from your computer. Try reinstalling the program to fix this error." So I tried to uninstall Fusion from control panel so I could do a clean install. When I try to uninstall, I get another error window titled "Windows Script Host" with the message "Could not find uninstaller to launch." Any help would be appreciated.
3 REPLIES 3
Mike.Grau
in reply to: llee
Hi @llee,
Could you try to do a clean uninstall which is described in the knowledge article here.
You may want to delete several folders and files manually before you re-install.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I hope the information in the article helps.
llee
in reply to: Mike.Grau
Mike,
That did the trick, thanks
Mike.Grau
in reply to: llee
Hi @llee,
Thank you, I´m glad to hear that it worked.
The clean uninstall article was the solution, great.
