Fusion 360 trial installation "Unexpected Error" web deploy.streamer.log
6 REPLIES 6
scottmoyse
1212 Views, 6 Replies
Hi I've just created a clean installed of OS x Yosemite. I created two accounts, the initial account is an iCloud account and has full admin rights. Fusion 360 installs fine there.
The second account was a standard user with Parental Controls turned on. Fusion 360 failed to install with the following error:
So I figure it was something to do with admin rights. However, when I looked up how to install as administrator, it seems Fusion 360 doesn't adhere to that standard? The Apple help documentation says it  automatically prompts for the admin password, but that event never occurs.
I cut my losses and made this account an administrator, if only temporarily, then restarted the Macbook. Logged back in and retried the installation. But I get the same error. There is no Library folder in the "tayla" account folder. I suppose it could be a hidden folder, but I can't see how to turn those on easily in OS x like you would in Windows and there is no way I can see to paste a path into Finder to force it to display that folder.
Currently this is a show stopper... what should I do next?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
6 REPLIES 6
O.Tan
in reply to: scottmoyse
To access hidden folders, you copy the folder destination given (/users/Tay.....), go to finder, at the top bar, click "go" and navigate to "go to folder", key in the folder destination and it should lead you right to it.
If it gives error like folder not found, remove from the right each character after " /"
My guess is for the sub account, you probably need to set up some settings to give it partial admin rights? Cause maybe Fusion uses some stuffs that requires admin privileges. Just saying
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
scottmoyse
in reply to: O.Tan
Thanks for the tip about navigating to hidden folders.
However as mentioned in the OP, the user has full admin rights.
Regards
Scott Moyse
MFG Technical Specialist
CADPRO Systems Ltd
0210557775
>From my Windows Phone
Scott Moyse
schneik-adsk
Admin rights are not require to install. Something else is amiss. Can you send the streamer log file to me?
Kevin Schneider
scottmoyse
in reply to: schneik-adsk
I had to copy it from finder to the desktop, so it could be navigated to from the choose file dialog in safari. Any tips for how to paste paths into that kind of dialog? Go To Folder doesn't seem to be available in that scenario. I know that question is outside of the scope of this forum, but if anyone can help expand my mind, that would be great.
Anyhow, Kevin, please find the log file attached. You will have to go back to the 2nd Nov since that's when it wouldn't install. For whatever reason, this morning at the first attempt it installed... I haven't changed anything overnight after the last two attempts yesterday. Hopefully the log file will paint the picture for the dev team.
Scott Moyse
schneik-adsk
We will look. and if i get you, all is working now? good.
Kevin Schneider
scottmoyse
Yes it is all working now. The only thing I can think I did, was browse to that folder before installing it this morning, which shouldn't make any difference really.
Scott Moyse
