Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fusion 360 to Rhino Vray
5 REPLIES 5
1318 Views, 5 Replies
Hi Guys,
Since I usually use Rhino Vray for rendering, I was wondering if its possible to import the surfaces from Fusion 360 into Rhino (not as a mesh) , if there was a file format that could preserve the surfaces of the model done in F360.
Basically:
Model In Fusion 360 > Rhino Vray
kind of workflow.
Is it possible?
5 REPLIES 5
cekuhnen
@Anonymous
Thats pretty simple
export as STEP and load the STEP into Rhino.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
in reply to: cekuhnen
Wouldnt the STEP file transform the model into a mesh? It makes it really hard to do any kind of rendering in Vray. Generally you want to preserve the NURBS or Tspline surfaces during the transfer
cekuhnen
@Anonymous
No STEP and IGES are surface bases formats / containers while OBJ STL are used traditionally to transport polygon based mesh models.
STEP is really the go to format send raw CAD data between apps.
Claas Kuhnen
Ah ok i understand now. Thanks for your input!
cekuhnen
@Anonymous
No worries. OBJ can also contain NURBS but realistically OBJ is mainly used for mesh transfer incl UV maps and material definition and STL well just for 3D printing.
Claas Kuhnen
Technology Administrators
