Fusion 360 simulation thin body's
LARA-Engineering
Message 1 of 12
LARA-Engineering
Hi
I'm new here (from The Netherlands) and have a first question.
Just started working with Fusion360ultimate simulation. But I can't find any feature to create shells for thin body's for meshing into plate elements, like can be done within Inventor. Does anybody know how this (thin body's/plates) works within Fusion Simulation? Normal solid elements does not work on thin body's, cause to much elements and nodes, long meshing-times and instability in results.
Freddy de Jong
LARA Engineering
Replies (11)
Message 2 of 12
John_Holtz
Autodesk Support
Autodesk Support
Hi Freddy. Welcome to Fusion!
Fusion Simulation does not have shell elements yet. For now, you will need to use one of our other simulation products (Nastran InCAD, Simulation Mechanical, etc.)
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Message 3 of 12
ken
You can try the Fusion 360 partner application SIMSOLID -- available in the app store. It can handle both thick and thin or large and small parts together in an assembly. It is based on new technology that does not require you to create a mid-surface and shell elements.
Ken Welch, SIMSOLID Corporation
Message 4 of 12
Noah_Katz
As an old-time FEA user, SIMSOLID sounds miraculous.
Busy learning F360 basics now but will delve into further later.
Ken, in the app store it says SIMSOLID is free; is that for a trial period?
If so, how long, and how much does it cost after that?
I have a hobbyist license if that matters.
Message 5 of 12
ken
The plugin for Fusion 360 is free.  It comes with a 30-day free trial of SIMSOLID.  After that you can license SIMSOLID by a monthly or annual subscription. Price starts at $200/mo.  SIMSOLID is a great complement to the embedded Fusion 360 simulation. It extends the analysis range to more complex parts (thick/thin, big/small features, many faces, etc) or very large assemblies. And, since there is no meshing, it eliminates all the typical FEA jargon stuff such as beams, shells, offsets, 1st order, 2nd order etc. that confuses many people.
Message 6 of 12
Noah_Katz
Can the subscription be turned on and off at will?
Any chance it could be made more granular, like by the day, hour, or even minute?
Maybe a Medicare license? 🙂
I'm a retired mechanical engineer hobbyist and my use will be intermittent.
Thanks, Ken
Message 7 of 12
ken
Well not from us.  Autodesk is the only one that can fund pricing like that. 🙂  We have to keep our lights on. That said, we are open for them to re-license it and sell it directly. I guess you should ask them.
In any case, the ability to analyze thin walled structures directly w/o all the hassle of shells is a feature that people really like about SIMSOLID.
Message 8 of 12
Noah_Katz
OK, so pricing is via Autodesk and you handle the tech side?
Message 9 of 12
Alessandra.G
Hi @Noah_Katz,
For the time being, the shortest subscription is the monthly one and we have no official information on any other subscription possibilities.
For further reference, you can have a look at our e-store for pricing and subscription models.
Alessandra G
Message 10 of 12
ken
Sorry for the confusion. All pricing for SIMSOLID can be found here
Message 11 of 12
Noah_Katz
OK, thanks, Ken.
Message 12 of 12
Noah_Katz
Allesandra, I couldn't find SIMSOLID in the store.
