Hello Having trouble running a static simulation on a assemby. I did two similiar simulations two weeks ago and they ran fine. I noticed the contact menu and options format has changed since that time. It used to allow seperation and sliding but now it looks like you have to pick on or the other? Not sure if that is part of the issue. I could aslo post the similiar models that have successfully run fine prior to the changes.
This is a good method for determining pin bending stress which is somewhat complicated and should not be ignored.
The error messages are below. I noticed someone else had the "Model contains 1 fully unconstrained group(s) in load case" on a post from 02_24_2016 but it was a different issue.
Thank you for any attention or replys
Summary:
Error: Solver Error
Error: An error occurred while solving the model.
Mesh Details:
39598 Tetrahedra : 100.0% of elements (100.0% of volume)
Face Angle min: 14.9, max : 146
Dihedral Angle min: 17.3, max : 150
Worst shape ratio : 6.71 on element 4733
Worst aspect ratio : 4.08 on element 5205, shortest edge: 0.00212, longest : 0.0356
Lowest collapse ratio : 0.231 on element 4733
Worst Jacobian ratio : 1 on element 1
Base mesh: 62134 nodes, 39598 elements
Solver mesh: 62134 nodes, 39598 elements
Job has finished with errors. Receiving results.
Error: Solver Error
Warning: Warning: Model contains 1 fully unconstrained group(s) in load case "Load Case:1".
Click here to select 'DOF View' to inspect.
Click here to select 'Manual Contact'.
Click here to select 'Automatic Contacts'.
