Fusion 360 Questions: Hide Grid & Change Lighting (for Mac)
billdresselhaus
Message 1 of 9
billdresselhaus
For Mac Version Fusion 360:
How does one hide the Fusion 360 grid for a nice snapshot or view without the grid showing (like in 123D Design)???
And how does one change the lighting in a Fusion 360 model (not rendered) in modeling mode???
Thanks, Bill Dresselhaus
Replies (8)
Message 2 of 9
Phil.E
To remove the layout grid display:
There isn't a direct lighting control outside of Render, but you may find enough variety by changing environments:
Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 9
billdresselhaus
Thank you, Phil!!!
Wow, getting an email telling me I had an answer is GREAT!!!
Bill
Message 5 of 9
I am attempting to hide the grid also. The "Layout grid" check box is grayed out so I cannot uncheck it.
Message 6 of 9
Hi @Anonymous
Make sure you are not in a sketch or a tool, "grid" is greyed out when you are editing a sketch or using some tools.
If you want to hide the sketch grid, check the sketch palette. There is a grid option there as well.
Good luck!
Message 7 of 9
JetForMe
Weird. My control for the grid is both disabled and unchecked, yet my grid is on:
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
Message 8 of 9
LogicSpeaks
My grid is also still visible even though it shows that its off.  Is this a bug?  It wasn't showing up a few moments ago, and now it just wont disappear no matter what I do with the settings.  I guess I'll try rebooting the program.
Message 9 of 9
LogicSpeaks
Ah... right... Autumn already answered my question... I had been in a sketch still and switched to CAM
Correction again --- I am out of sketch mode and yet the grid is still visible even when the grid is unchecked in "grid and snap" settings.
