Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Fusion 360 plane when starting a sketch
2 REPLIES 2
Jeeson.G1
194 Views, 2 Replies
Hello, when starting a sketch in fusion 360 my planes used to look like this Plane fusion 360.PNG
But now after an update it looks like this
How do I go back because I am trying to follow a video and for some reason the plane being like that messes up the thing.
Thank you
2 REPLIES 2
dsouzasujay
in reply to: Jeeson.G1
@Jeeson.G1
From the Navigation Bar> Environment select Dark Sky
2. Go to Preferences> Default Modelling Orientation>Y Up
3. Create a new document to see the changes
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
jeff_strater
In addition to the environment, it also looks like you have switched to a "Z-up" orientation.  If you want to go back to "Y-up", use this preference, and choose "Y-up":
Jeff Strater
Engineering Director
Technology Administrators
