Fusion 360 - Multiple Designs one Drawing
wesley.bonafe
wesley.bonafe
Is it currently possible to place multiple designs in on drawing? I have a curved piece of trakk, Image attached.  I need to indicate how the rails would be built if they were straight.  I can draw what I want but cant figure out how to display it with the attached curve.  If I draw what won't exist (An intermediate step) do I need a completely separate drawing?
atherisinnovations
By "Drawing" you mean sketch, right? Not inserting a dxf or svg. I also would like my sketches to be more accessible to other projects.
I had suggested a'sketch library' in the Ideastation like 4 months ago but that was shot down..
Just designating a moveable 'handle point' somewhere in the 2D sketch area would make it easy to pull into an existing project and align correctly. I often have designs that can have more than 10 variants and it gets to be a chore with project management to remember where the correct sketches are and if they are contained in the component folder or not.
Maowen_Zhang
@wesley.bonafe, if you want to show sketch curves after creating a feature, could click light bubble to show sketch in browser. One sketch could contains multi curves, and we could use it for creating multi features / bodies.
Lori Zhang (Fusion Development)
zhixin.ni
You can place multiple designs in one file by creating one component for one design. You can make the component invisible if needed.
Regards
Nick Ni
