Fusion 360 is set up for inches. When I use Make/3dPrint and import the .stl file into Cura (current release) I cannot find anywhere to do the conversion to metric.
Presumably I could scale the drawing in Fusion by 25.4 but would then have to scale back after the export.
On the Make/3dPrint panel there is a checkbox for "send to 3d print utility". When this is checked the OK button is not active. The "download Autodesk print studio" does nothing. I'm new to this and wondered if print studio might help?
