Fusion 360 import Inventor file with history?
Ezekiel12
Ezekiel12
is there a way how to import Inventor IPT into Fusion even with part history? I know that there is a tool Find Features, but that is not exactly always perfect. And Inventor and Fusion are both Autodesk CAD products, so I did not dint any info about it, but I'm trying it here, maybe I just missed something 🙂
And I mean, the possibility to have sketches, work planes, etc...
Thank you and have a nice day,
Matt
Beyondforce
Hi @Ezekiel12,
Unfortunately, it's not do that yet. When you import a file, which is not a Fusion native file, the components will be imported as solids. But you can still edit them in Direct mode.
Watch this: http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2016/fusion-360/pd16277#chapter=0
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
O.Tan
Nope, unlikely to happen cause each software has their own way of doing things, even though both softwares are from AD, they don't share the same code base. In Inventor there's AnyCAD which sorta solves different file format interoperability and I expect that we will see similar feature some unknown time in the future. Though don't put your hopes on it yet cause Fusion now has a huge backlog on needed features to be implemented/improved.
If I may ask, what are you doing now and such with Inventor and Fusion? I may be able to offer some workflow suggestions
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
gerrit36NS2
HughesTooling
@gerrit36NS2 You can import inventor files but they will not have the history tree, the will be dumb solids just like importing a STP, IGS etc.
Mark
Mark Hughes
Owner, Hughes Tooling
