Bug: Shell + Fillet
Bug: Shell + Fillet
jsejcksn
Bug: Shell + Fillet
jsejcksn
I found a bug!
When I shell a body and then fillet the edge such that the fillet intersects the inside the of the body, I should get an error. No error here, and not even two resulting bodies!! Really weird.
Beyondforce
Hi @jsejcksn,
This is not a bug. You need first to create the Filet and then create the Shell. The Filet takes off materials and you did it after the shell, which didn't left enough material to remove!
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
