11:42 AM
While in cam, and editing a 2D contour, I select the gemoetry tab and then check the "tab" checkbox. Fusion hangs and has to be closed every time.
This appears to happen only with existing drawings. I created simple cylinder and set up a 2d contour on it, with tabs, and did not have any trouble.
I posted to the CAM board last week, and they said a new update would fix it. It helped, because my original problem was just that it would crash just when selecting the geomotry tab. After thier update, I could select the geometry tab, and check any of the others boxes on it, except the "tab" checkbox.
I've included a diagnostic zip for your reference.
Thanks!
D
