Fusion 360 hangs whenever I select the "tab" checkbox
While in cam, and editing a 2D contour, I select the gemoetry tab and then check the "tab" checkbox.  Fusion hangs and has to be closed every time.
This appears to happen only with existing drawings.  I created simple cylinder and set up a 2d contour on it, with tabs, and did not have any trouble.
I posted to the CAM board last week, and they said a new update would fix it.  It helped, because my original problem was just that it would crash just when selecting the geomotry tab. After thier update, I could select the geometry tab, and check any of the others boxes on it, except the "tab" checkbox.
I've included a diagnostic zip for your reference.
Thanks!
D
Phil.E
There is another related fix that may help in your case. It's supposed to come out on Wednesday. Try again after that and let us know how it goes please!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Fusion did not update when I signed in tonight at 8:45 EST.  Assuming the update did not post yet?
brianrepp
@Anonymous Correct, the update finished at approx. 9:45pm EST
Bang.  That worked.  Thanks!
