Fusion 360 for DIE Draw animation
Hello every one, I'm trying to animate my die and punch mechanism to draw sheet metal and see the results, can any one guide me how i can do this, so that i cam understand the behaviour of the die and my drawn part after making the die. I want my die and punch animate in fusion 360 and blank my sheet to show me the result. as in this video below link.  I tried 2 dies earlier but after making dies through CNC machine, I couldn't get desired output, any help will be appreciated. Kindly response as early as possible.
I need animation like these one.
https://www.youtube.com/watch?v=Fid1r3tG538
Regards:
Mazhar Ali
B.Sc Mechanical Engineering Student @ Bahauddin Zakariya University Multan Pakistan.Screenshot (33).pngScreenshot (34).pngScreenshot (35).png
paul.clauss
Hi @Anonymous
Thanks for posting! While you will not be able show the actual deformation of the stamped part in the die, you could use the Animations workspace in Fusion to create a simplified animations in which the two sides of the die are brought together on a blank sheet (which would be a different component than the modeled stamped part). You could then switch off the visibility of the flat blank and switch on the visibility of the stamped part and then retract the dies. This may allow you to develop a simplified animation of this process.
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
Sir,
Thank you for your kind response, I'll try this, I'm sure this will help
me,
Again Thank you for your response.
Stay Blessed.
