Fusion 360 background issue
I'm fairly new to Fusion 360 so bear with me.
I have recently downloaded the program on to my computer and for some reason the design area is grey and I can't see any models when I open them.
I have previously used it on my laptop and the background was white and the grid is clearly visible along with any models I opened.
Does anyone know how to correct this please?
laughingcreek
You might start by checking your environment settings (bottom of the screen).
can you give us a screen shot of what you see?
i'm have got the same problem.
i know my graphic card is old but with all other 3d cad it works well.
i only need to view the grid, no render or intesive features.
i need to change the backgroud color or remove any other effect.
thanks
g-andresen
can you upload the f3d-file. > export > save > attach
regards
günther
done.
on mouse on it you can see the cylinder
thanks
g-andresen
for me all is fine.
Try th following:
1. reset default layout
2. Preferences > graphic setup  > change some parameter (antialiasing >off)
3. clear data cache
4. contact support
regards
günther
