Fusion 360 and CNC Lathes
Message 1 of 19
I have designed a project to be manufactured on a CNC lathe. I have the latest version of 360 and I cannot find any support to set up the tool paths for a lathe. Am I missing something???
Thak you in advance.
Mike
Replies (18)
Message 2 of 19
CGPM
This reply has been edited by the moderation team as the legacy links were no longer valid
No lathe support at this time, and the wrong forum for Cam 360 questions.  They should be at http://camforum.autodesk.com/
Message 3 of 19
Oceanconcepts
Well, we do have tool path creation and CAM as an integral part of Fusion 360- I for one would be interested in knowing if lathe support is planned.
- Ron
Mostly Mac- currently M1 MacBook Pro
Message 4 of 19
jeff.walters
Yes lathe is absolutely planed. But we don’t have a definite timeframe for it yet.
Jeff Walters
Senior Support Engineer, CAM
Message 5 of 19
bespenship
Thanks guys.
Lathe (turning) support is on our roadmap.  Thanks for letting people know there is a CAM-specific forum - we all work together on the Autodesk side, and we'll grab folks from our CAM team when needed, so no need to be overly concerned about where you post.
Brent Espenship
Fusion 360 Quality
Macbook Pro retina - MacOS X 10.11.5 (main)
WIndows 7 Notebook
Message 6 of 19
Thanks for all of the help. I did not know about the lathe specific forum but I do now.
Mike
Message 7 of 19
Please, add Lathe (turning) support.
Message 8 of 19
curtis.chan
Hi Aargear,
Totally understandable in regards to Lathe functionality.  One nice feature that is coming out in the November 15th release is the ability to select cylindrical stock, if that could be of value.  We've had lots of request for that as well.
Message 9 of 19
Thanks. We wait Lathe (turning) support.
Message 10 of 19
johnson2423
Im ready for lathe tool paths please!!!
Message 11 of 19
griffew
Turning has been added to Fusion 360 CAM!!
Message 12 of 19
johnson2423
I'm inordinately excited about this.
Message 13 of 19
230roblittle
ASAP please !
Message 14 of 19
HughesTooling
Did you read post #11, turning has been in Fusion for about a year.
Link to Help.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 15 of 19
230roblittle
Nice!
Message 16 of 19
The Fusion 360 lathe CAM section is beautifully logical in the sequence of operations, and I have modelled some complicated projects. Unfortunately I am running Mach3 Turn I am obliged to use the Generic Fanuc post processor and then play around with the output. Does anyone know of a bespoke post processor for Mach3 Turn, or whether Autodesk will be issuing one any time soon?
Message 17 of 19
HughesTooling
I've tried to help a few people customise a post for mach3 turn but it's not been easy. Either they don't come back so you don't know it it's working or they have no idea about G code or mach3 and it's impossible to get it sorted. The problems are mostly to do with arcs and whether the tool is at the front or back. What problems are you having and are you able to correct the code from the fanuc post to show where the problems are.
Have you done a search on the CAM forum, someone did post up a post they were using.
Mark
Mark Hughes
Message 18 of 19
Hi Mark
The problem varies - sometimes the code is good but the tool path image in Mach3 is hopelessly wrong,and it's only by running it that I can see that it's OK. Other times the reverse is true and on some occasions all seems fine and then something untoward happens. In most cases where it fails there are arcs in the cut file, which would appear to support your point. I will visit the CAM site and see what I can unearth. Do yo know if Autodesk are working on the postprocessor list?
Ron
Packman Lucas
Message 19 of 19
HughesTooling
The problem seems to be mach or perhaps just the people trying to set it up have not looked at how other controls work. I have 2 lathes one with a Fanuc control and one with a cheap Chinese Fanuc clone both have the tool nearest the operator. In this configuration a lot of the mach3 people have it set up so X is minus, this seems wrong. On my machines I just program a diameter say 30mm I don't program -30mm. Having the X reversed also reverses arc direction so it gets even more confusing.
If you can hand code a simple part then it is easy enough to modify the post to match but just throwing code into the machine and seeing what happens is quite a challenge if you can't manually program G code and modify posts.
Mark
Mark Hughes
