Fusion 360 and ArcGIS
Can ArcGIS be plugged in Fusion 360? How to use ArcGIS for Fusion360?
jeff_strater
There is no plugin for this software in Fusion.  What do you want to do with this software in Fusion?
I don't know anything about ArcGIS, but if it can export DXF, STEP, IGES, etc, you can import that information into Fusion.  However, be aware:  GIS data tends to be quite large, and if you import 2D data into a Fusion sketch, your performance will likely be pretty bad.  So, be careful with this workflow.
Jeff
Jeff Strater
Engineering Director
