fusion 360 2d sketch dynamic?
Can you use constraints to make 2d sketches in fusion 360 that are dynamic?  Kind of like you can make movable sketch blocks in Inventor of ForceEffect?
innovatenate
Autodesk Support
Autodesk Support
Sketch constraints should be solved and updated as the sketch is modified. There is not currently a block feature like Inventor's, so the dimensions and constraints would need to define sketch entities so they have the correct degrees of freedom. Depending on how complicated your sketch, you may not need blocks.
This would be great suggestion to add to the IdeaStation.
Fusion 360 IdeaStation:
http://forums.autodesk.com/t5/ideas/v2/ideaexchangepage/blog-id/125
Let me know if you have any questions!
Nathan Chandler
Principal Specialist
