Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi, I am about to go bonkers, my OCD can't handle this, is there anyway to adjust the border to centre on the page in Fusion 360 when doing drawings?, I use the ISO standard with the A4 page size in landscape, for some reason the border won't center, and to make it worse, when I move it the edges also move...........please I cant deal!!!
Solved by mishrani. Go to Solution.
Hi @Anonymous,
The border for the ISO drawing has been set as per the ISO standard which requires a 20mm border to the left hand edge (for filing) and a 10mm border round the other three sides of the drawing sheet.
But if you still want the replace the existing border, the only way as of now is to create a custom Title Block that includes border
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-D6DB9443-A21B-4E23-8C4F-B275102715AB
@mishrani, Thank you for the reply, sorry I am totally new to everything technical, 5yrs old and loving the learning experience of Fusion 360, I never knew there was a standard, I guess they never thought of those with severe OCD lol, thanks again, custom border it is then.
