Fully Define Sketch
Fully Define Sketch
Message 1 of 8
Fully Define Sketch
hello,
how can i know that my sketch is full defined ?
thank you
Replies (7)
Message 2 of 8
TrippyLighting
That functionality is in preview. You can enable it in the preferences under "Preview"
Message 3 of 8
thank you
Message 4 of 8
Forgive me for bringing up this old thread, but can you please go into detail about how to enable enforcement of fully defined sketches?  I cannot see an option for this in "Preview".
It seems that my sketches are allowed to be left without being fully defined before I use them in features.  In SolidWorks I can set this to be enforced so that I cannot even exit the sketch unless it's fully defined.
Message 5 of 8
TrippyLighting
In Fusion 360 you cannot. It's that simple. This feature was in preview for a long time but is now a normal feature that still occasionally fails.
Once al sketch elements have turned black - with the  exception of construction lines ans projected sketch items - the sketch theoretically should be fully defined.
Message 6 of 8
What other means do we have at our disposal to prevent problems with this then?
I don't really understand how a sketch may be allowed to be left under-defined before being used in future timeline features.
It seems that I can drag the edge of a cylinder (without being in edit mode) and have the entire model just explode before my eyes.
Message 7 of 8
Hi, you can forcefully fix it under constrain menu.
Message 8 of 8
chrisplyler
A sketch may be allowed to be left under-defined...because Autodesk did not bake any enforcement into the software.
When a sketch IS fully defined, you will see a little red padlock icon atop the sketch's entry in the Browser. If it is NOT, you will instead see a little pencil icon there, suggesting that you continue editing the sketch.
It is up to the user to understand how to achieve a fully defined sketch, and enforce his own choice to do it.
Sometimes a user will CHOSE to leave some bit of a sketch under-defined, such that said user can drag (the edge of a cylinder perhaps) to watch his model explode all over the place. Or, more realistically, to make small adjustments by dragging until a design decision is made, at which point the bit can be locked down.
