Fully contraint components from an assembly move when inserted or multiplied
I often face this problem that when i have created an assemlby(with fully contraint components) that the components move radomly when: inserted into a new assembly or multiplied(pattern).
Some times the components jump back to the original location but also often not.
If anybody has advice please help.
Best,
Maarten
TheCADWhisperer
jeff_strater
two things to be aware of (not sure if these are related to your problem or not, until we can see your models)
  1. ground does not come across when a design is inserted
  2. if the design is saved with "capture position pending":
    that uncaptured position can be ignored on insert, which can cause components to move back to their home positions
or, it could be a bug...
Jeff Strater
Engineering Director
Hi Jeff,
Thank you for your reply
Could I share your model with you directly as I can't share the model with everybody on the forum?
Best,
Maarten
jeff_strater
certainly.  If you have a commercial license, then Share Public Link is the easiest way:
making sure that "allow download" is on, get the link and you can DM it to me here on the forum.  If you have a Personal license, then the best way is to export the design as a "Fusion Archive (F3Z)", and either put it on some file-sharing site, or, if it is small enough, just email it to me at jeff.strater@autodesk.com.  Thanks!
Jeff Strater
TrippyLighting
@jeff_strater I've seen this in my own assemblies as well and believe this is a bug.
The assembly is usually fine as a "compute all" takes care of it.
jeff_strater
Sorry for the delay in replying.  Thank you for sharing the design, @Anonymous.  However, I don't see the same behavior.  Am I doing something differently?  The design is slightly different than in your video, but I'm wondering what else might be different.
Jeff Strater
