From designing to drawing sheet color has changed
Rajvijay_Baskar
Observer Observer
Rajvijay_Baskar
Observer
Observer
Recently I had done some cable harness after I take to drawing sheet the appearance of the cable was changed,
Why this happened?
For reference I have attached the images.
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the post.
günther
Rajvijay_Baskar
Observer
Observer
I attached the fusion file. Can you check
g-andresen
that´s what I see
1. check your graphic settings an update drivers
2. Service Utilities > Repair
günther
Rajvijay_Baskar
Observer
Observer
Can you outline the process you followed for the assembly drawing?
g-andresen
DESIGN > Drawing > From Design > Top View > Detail
günther
