Frame generator ?? this is my best approach but...
ALE.REAL3D
ALE.REAL3D
Is there a better way to do it?
I will like to see the experts approach the creation of a parametric frame that has miter corners and adapts to a volume previously set ( shadow)
I am sure that you out there have a better way
and I will be very thankful if you can guide me to a wiser solution
Thanks a lot to all
Alejandro
davebYYPCU
Might not be better, right or wrong, (it's subjective) I started over, with your parameters.
I have not seen the move command used for that before.
Step up Timeline.  You will see I did not need the Shadow.
Your Spreaders were not shelled, so I did not do mine, easy to fix, with Shell before the pattern.
I was not able to input your shell thickness parameter in that feature.
Might help...
ALE.REAL3D
Sorry for my very late answer
It's brilliant the way you solve this and I am happy that you took the time to show me a different approach
Thanks a lot
