Force Simulation
Force Simulation
heyarn
Force Simulation
heyarn
I'd like to learn how to use the new simulation feature, specifically, I'd like to learn how to study the effecot of different forces on the frame that I designed in 360. Is there a youtube tutorial that I could look into? Or some documentation, or tutorial file?
Thanks in advance!
Pavel_Holecek
Hallo,
Thank you for your post.
You can assess online Help and step-by step tutorials using the Help button in the right-upper corner of Fusion 360. Tutorials are located in the Function area.
We had also posted a blog earlier describing various way to learn Simulation in Fusion 360.
It is located here: http://forums.autodesk.com/t5/design-differently/start-learning-fusion-360-simulation/ba-p/5841674
Hope this helps you start using simulation successfully!
Regards
Pavel
Pavel Holecek
Autodesk QA team
