Font compatibility
Font compatibility
Font compatibility
Looking for help getting these 2 fonts to work.  I've read through the previous posts with no success.
Thanks!
HughesTooling
If a font doesn't work in Fusion your only option is to use another program to convert the text to curves then import. @PhilProcarioJr has a tips thread here. The SVG importer has been updated since the tips thread was made so the scale will be different but you can scale sketches in Fusion now.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Here's another way to get text into Fusion using QCad. The advantage here is no need to scale as the DXF has the unit information in it.
Mark
Mark Hughes
