Fluid Simulation with a turbine
thansiyapa
thansiyapa
Can we do fluid simulation of a turbine in fusion 360... if yes, will the results be accurate? Should i need to switch on to autodesk CFD for that...
John_Holtz
Autodesk Support
Autodesk Support
Hi @thansiyapa
Fusion does not have any CFD capability. You need to use Autodesk CFD to perform the analysis.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
