Flex PCB
Flex PCB
Flex PCB
Hi all! new person also here. I couldn't find if the flex pcbs are supported to integrate it with the 3d housing, or at least in progress. If yes, is there any tutorial on how to make it and how to adapt it to a curved section?
Thank you! 🙂
TrippyLighting
Fusion 360 is not a PCB design software, but it does have some integration with Eagle, which, on the other hand does not support development of flex PCB-s in a 3D environment.
It is imaginable, however, that the sheetmetal environment in Fusion 360 can be used to simulate the geometry of a flex PCB's.
