Flattened Pattern to step
dankendall313
dankendall313
Can anyone help me with a work around? It seems that Fusion will not export a flattened pattern to a step. This is necessary to inspect the laser cut piece before bending used laser scanner.
g-andresen
File > Export >   select STEP !
günther
etfrench
Will 'Save as Mesh' give you a result you can use?
Here is the mesh imported back into the original file.
ETFrench
jhackney1972
A Flat Pattern, as you  say, not export to a STEP but a sheet metal model, that is in an Unfold state will.  The Screencast will explain.
John Hackney, Retired
dankendall313
Thats great! Thank you.
jhackney1972
If my answer has provided a solution to your question, please click on Accept Solution icon to acknowledge this and make the solution available to others.  If you have further questions, please ask.
hamid.sh.
@jhackney1972 's exporting from unfold is easier, but you can also export from flat pattern. In a new file you can insert flat pattern as Derive (select Flat Pattern from Browser):
Insert Derive brings flat pattern body to the new file. Now export from this file:
Hamid
