- Mute
- Permalink
- Report
Imagine you have a rectangular box, without the top. You have two sides, a front, back, and bottom. My goal is to take this box and flatten it onto a horizontal surface, giving space between each body of the rectangular box. The purpose of all of this is so a CNC plasma can cut all the parts, which I can then weld together.
As a first pass, I went the parametric route, and for each side of the rectangle, I would draw a separate sketch onto the horizontal surface using the appropriate variables to scale. This worked fine using the simple rectangle, but it became a maintenance burden as I added more complex parts. Another downside is that for each body, I must create a separate sketch, which increases the margin for error.
I am very new to this, but I believe what I want to do is to project the bodies mentioned above onto a horizontal surface. In the case of the rectangle example, the sides are vertical, yet the surface I am project to is horizontal on a different axis. I tried "project to surface" but no luck. Any ideas?
Thanks!
