Flat pattern after scaling sheet metal
FacebookGroupMember
FacebookGroupMember
Hi. Just another question once you scale a component that is sheet metal with bends can you then open it to a flat pattern. Currently trying and it won't once scaled. The original will create a pattern but then I can't scale it while as a pattern. I need it to create an annotated drawing for laser cutters. TIA
jhackney1972
Do the scaling in the 2D drawing as you place the flat pattern view not in the sheet metal model.
John Hackney, Retired
g-andresen
scaling a sheet metal part would change the length and width as well as the thickness.
But that makes no sense.
günther
