Flange tool won't select desired edge
mattherrick95
Observer Observer
Message 1 of 8
mattherrick95
Observer
Observer
I'd like to connect the top and bottom flange to the front flange but I can't select the bottom edge of either like I did with the piece that is detatched. Please help
Replies (7)
Message 2 of 8
dominik_zarczynski
Hello Matt,
Is that what you wanted to achieve?
3D:
Flat pattern:
If yes, let me know so I can describe in details how I did it.
If no, please explain (best with print screens) so I can better understand.
If my answer helped you, please click Accept Solution. Thanks!
Dominik Żarczyński
Customer Technical Success
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 8
user015M86Y
Hi, can you describe how you did it. Thank you
Message 4 of 8
mattherrick95
Observer
Observer
This is what I'm looking for but with flanges
Message 5 of 8
TrippyLighting
The attached model contains a way of modeling the finished form and then converting that into a sheet metal body.
However, in order to generate a flat pattern, each of the two halves has to be a separate component.
So after the 3D sketch, you need to create two (empty) components,  one for the top and one for the bottom half.
Then activate each component before doing the sheet metal stuff.
Message 6 of 8
mattherrick95
Observer
Observer
Thankyou so much! It worked out great.
Message 7 of 8
dominik_zarczynski
1) Create a flange from this edge.
2) Create a sketch on this flange using Project function in a sketch and extrude
3) Cut the unnecessary material with extrude.
4) Mirror what you did. To do that - first construct midplane.
Dominik Żarczyński
Message 8 of 8
johnsonshiue
Hi Folks,
Here is another solution using a different modeling technique. Basically, you may focus on creating the non-sheet metal body. Round the sharp edges with desirable radius. Then create a zero-offset surface (leave an opening). Lastly, thicken surface logically so that the part can be unfolded.
Many thanks!
Software Test Engineer
