Message 1 of 12
So I have a step file and the person who made it wasnt careful on his draft and radii and there are some micro geometry issues causing havoc on the CAM side of things. I have also experienced times when I would like to remove all draft but have not yet found an effective way to do this. Trying to accomplish 2 things with this post but might have the same solution.
1) A time efficient way to tweak individual draft surfaces.
2) A time efficient way to remove all draft but retain radii.
I highlighted the draft issue in the model. the draft highlighted is .5 degrees different than the draft elsewhere, causing a step of a couple tenths where it should be continuous.
