Fix an accidentally moved component's location without messing up references?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Have attached both the design file and will a screencast. Please have a look.
After copying and placing a component (FrameHorizFullWidth:5) into its proper location, I continued on designing.
One of the MANY things done after placing the component in question was that I used the edge of it (projected into a new sketch in a new component) to control the length and end position of another component.
I then discovered that altering the user parameter "FrameStockThickness" would cause the top face of two components (one was FrameHorizFullWidth:5) to change in the 'wrong' direction.
I rotated both of those components 180 degrees top to bottom, and 180 degrees end to end. This addressed the issue of enlarging on the wrong side, and at this time FrameHorizFullWidth:5 looked to be in the right place.
I have just discovered that FrameHorizFullWidth:5 is NOT in the correct position - and I can' figure out how to fix it.
Simply using "Move" to move FrameHorizFullWidth:5 will put it back where it should be, but then it interferes (overlaps) with the part that uses FrameHorizFullWidth:5 as its length reference.
Please have a look at the design and the (sorry so long) screencast, and give me some guidance?
Thanks...
