First/Third Angle Projection Symbol
Hi all.
Just a quick question. When creating the drawing, how do you insert the projection symbol (first/third angle) ? I'm assuming it's possible.
Sam
innovatenate
Autodesk Support
Autodesk Support
First/Third Angle Project symbols are not included in the Text Symbols at this time.
You may be able to import a custom template (from another program like AutoCAD or Inventor)  with the projection angles drawn on them. Or edit a template to include an image of the the Angle Projection. Check out the latest update on our blog for more information about drawings.
http://www.autodesk.com/products/fusion-360/blog/2d-drawings-check-roadmap/
I hope that helps! Let me know if you have any questions.
Nathan Chandler
Principal Specialist
