First sketch tutorial, Equal constraint working backwards?
Message 1 of 30
I'm trying to do the first Sketch tutorial, but, when he uses the Equal constraint on the right end, and then the left end, his right end matches to his left end... however, no matter how I do it, the left end always matches the right end, instead.
What am I missing? Because he just jumps to it.
Replies (29)
Message 2 of 30
Beyondforce
That's a good question, maybe they have changed something since this video has been made. I get the same results.
Maybe @Aaron.Magnin could answer your question?
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 30
I ended up throwing the whole thing out and starting from scratch... I did everything exactly the same, exactly like he does it in the video (which is precisely what I did last time), and this time the Equal constraint is working like he uses it.
I have absolutely zero... idea... why.
Message 4 of 30
Beyondforce
No matter what, the first line that you chose, that the line that you want to change!
I hope Aaron have an answer for that.
Ben.
Ben Korez
| YouTube
Message 5 of 30
PhilProcarioJr
@Anonymous
Actually it only visually does that, if you dimension the line on the left the line on the right will update correctly. So it's not that anything is wrong you just haven't gone far enough. If you continue on in the tutorial you will get the correct results.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 6 of 30
I figured this out once I got into the modeling tutorial... but I seriously spent two hours trying to work out what I was doing wrong because what that constraint does and how it operates wasn't even touched on. I had no clue. I thought maybe I'd done something wrong and was completely screwing it up.
Message 7 of 30
PhilProcarioJr
@Anonymous
I understand everything your saying and I agree the training could be a lot better. The guys behind the training are working to make it better. Lets make sure @Aaron.Magnin knows about this.
Phil Procario Jr.
Message 8 of 30
Beyondforce
I always thought, that the first line you mark, that's the line that change, like in Inventor!
Ben Korez
| YouTube
Message 9 of 30
PhilProcarioJr
@Beyondforce
"I always thought, that the first line you mark, that's the line that change, like in Inventor!"
It's like that in Solidworks too....
In my opinion that's how it should be. I think the problem here is two fold:
1) Getting the intended results when using a tool. The video clearly shows this is broken now.
2) Training explaining things better for new users.
Both of these in my opinion need fixed.
Phil Procario Jr.
Message 10 of 30
Beyondforce
We are working on that 😉
Ben Korez
| YouTube
Message 11 of 30
PhilProcarioJr
@Beyondforce
Good luck with that. Smiley Wink
Phil Procario Jr.
Message 12 of 30
Aaron.Magnin
In my tests, the equal constraint will use the first selection to drive the second. Not sure if this was changed, but I don't know why they would have.
Is that what everyone else is seeing/experiencing?
Aaron Magnin
Technical Marketing Manager Fusion 360
Message 13 of 30
PhilProcarioJr
@Aaron.Magnin
Yes the results are the opposite of what is shown in the training....
Phil Procario Jr.
Message 14 of 30
Beyondforce
Ben Korez
| YouTube
Message 15 of 30
Aaron.Magnin
Okay....thats weird. I'll try to see what happened, but for now just flip your selection.
Aaron Magnin
Message 16 of 30
PhilProcarioJr
@Aaron.Magnin
I don't care one way or the other as it has zero effect on my workflow, but once again a video doesn't explain this good enough for a new user then the video doesn't match what's happening in Fusion so they become further lost, frustrated and confused. The amount of posts from new users confused by lack of information and out of date videos is starting to stack up...
Just thought ADSK might want to know about this....
Phil Procario Jr.
Message 17 of 30
Aaron.Magnin
We definitely do care about this feedback. Thanks for adding me to the conversation!
Aaron Magnin
Message 18 of 30
Oh, this became a much bigger deal than I expected. Yeah, I'm a complete newb and I didn't realize that it would tie them together so adjusting the dimension of either would adjust both... I was just parroting what the video did, but there's a time or two where it just kinda skims ahead and I had to work out what happened by the changes on the screen, such as where the horizontal/vertical constraints and equal constraints were applied.
What threw me was that what I saw was not emulating what the video showed and I got mega hung up on that, just because I didn't realize it was adjustable til later.
Thanks for not making me feel like a complete failure, though! This is exceptionally encouraging!
Message 19 of 30
Hmmm. Not far off a year later and the tutorial video is still the same. New user here so still confused. Perhaps there is some youtube video's will explain things better?
Texy
Message 20 of 30
Beyondforce
Hey @Anonymous,
If you could be a bit more specific about what you need, we will do our best to help you.
Cheers/ Ben
Ben Korez
| YouTube
