Find Feature in Timeline
tookemtoni
tookemtoni
Hi, What is the quickest way to find a feature in the timeline?  I wish the right click on feature would have an option to highlight feature in timeline.
HughesTooling
Fusion doesn't have a select feature option so you need to click and hold then from the parents list you can select the feature then you can select find in time line.
Click and hold.
Then select feature
That said, Fusion obviously knows you selected a face that's part of a feature and gives you the option to Edit Feature. Although you selected an edge in your example so you don't get that option.
Mark Hughes
Owner, Hughes Tooling
tookemtoni
So cool. I use left click and hold all the time and I didn't know about the parents tab! Thank You!
nocturnalwelding
pretty cool, thanks
busycleta
Hi
Please help with some advice if possible. When select and / or right click a component, and then head to the "find in timeline" command , it never points me to the component creating feature that is actually a point in the timeline. How can I make this work as expected?
swamp2
Similar to above, I can not get to the menu with "Show in Timeline", perhaps this has been removed?
