Fusion doesn't have a select feature option so you need to click and hold then from the parents list you can select the feature then you can select find in time line.
Click and hold.
Then select feature
That said, Fusion obviously knows you selected a face that's part of a feature and gives you the option to Edit Feature. Although you selected an edge in your example so you don't get that option.
Mark Hughes
Owner, Hughes Tooling
