Filling inside a model
7 REPLIES 7
Message 1 of 8
joao.silveiraGDTLR
385 Views, 7 Replies
I am trying to make a model solid inside, but it doesn't work. I tried by A360 and Meshmixer, but I think that the structure is too complex. Has anybody an idea how (or where) to do it?
Many thanks!
Tags (4)
Labels (1)
7 REPLIES 7
Message 2 of 8
1. Reduce Faces : MESH  > Modify > Reduce (40%)
2. Mesh > Modify > Convert to BREP
günther
Message 3 of 8
Quicker and a better model if you model it from scratch.
Might help....
Message 4 of 8
wersy
in reply to: davebYYPCU
I did something same.
Message 5 of 8
wersy
in reply to: wersy
I just looked at my plug to check the diameter. Purely by chance I had made it exact 6.3 mm.
But there is still something missing:
Message 6 of 8
good suggestion, but I am far away to be good enough in F360, so I could draw it by myself. I am still learning. But thanks!
Message 7 of 8
I will try, txs
Message 8 of 8
joao.silveiraGDTLR
in reply to: wersy
Thanks! I was able to use your file and fill in with a cylinder.
